TwinTurbo.NET: Nissan 300ZX forum - Re: I assume code 55?
gjohnson25
on July 19, 2008 at 1:08 PM
I assume code 55? (n/m)
posted by SuparexTT
on July 19, 2008 at 01:04 PM
I fixed the error code problems I was having... had 02 sensors error and knock sensor error
Failed State Inspection, Need Help
gjohnson25
11:33:59 07/19/08
how old are your O2 sensors?
Waggz
12:02:09 07/19/08
Re: how old are your O2 sensors?
gjohnson25
12:15:17 07/19/08
Why?
Audicon
13:17:57 07/19/08
Re: Why?
gjohnson25
13:29:37 07/19/08
That is true. I have a NA and just deleted my EGR and
Beaker5196
13:43:21 07/19/08
I stand corrected. (n/m)
Audicon
20:56:49 07/19/08
SuparexTT
13:04:07 07/19/08
Re: I assume code 55? -
gjohnson25
13:08:06 07/19/08
have you checked your timing? (n/m)
aliaZ
13:14:37 07/19/08
Re: have you checked your timing?
gjohnson25
13:15:55 07/19/08
too much timing can cause high NOx (n/m)
aliaZ
13:19:19 07/19/08
I have read that some here have retarded their timing to
doug8867
13:56:27 07/19/08
Crank your timing as far back as you can... then go pass
jcieslik
17:04:31 07/19/08
How are your Cats?
DreamZ90
13:17:39 07/19/08
Re: How are your Cats?
gjohnson25
13:32:18 07/19/08
Might wanna check, you should be able...
tdogzjoint
15:21:58 07/19/08
Re: Failed State Inspection, Need Help
onewheelf4
13:36:13 07/19/08
Re: Re: Failed State Inspection, Need Help
gjohnson25
13:52:02 07/19/08
clogged cats? (n/m)
14:01:33 07/19/08
Re: clogged cats?
gjohnson25
14:07:06 07/19/08
I'll give you 3 guesses (n/m)
14:07:44 07/19/08
Re: I'll give you 3 guesses
gjohnson25
14:24:44 07/19/08
I dunno, but if I wasn't mechanically inclined enough to do
16:57:08 07/19/08
borrowing a fellow Z's cats for the day (n/m)
Atl300zxTT
10:27:32 07/21/08
Check out the timing tweak FAQ in the TECH section of
doug8867
10:15:37 07/22/08
Try some "guaranteed to pass"
Josef(Houston)
15:23:37 07/19/08
Here's the hints Kinda long.
jjpp2Z
16:15:02 07/19/08
My '93 no longer required to pass in NC. (n/m)
cherryz
09:40:03 07/21/08
